1 - 2 of 2 Posts
I have been trying to get the horn to work on my 65. The relay is okay and so are the connections from the wheel. I think I have all the pieces from ther ring type horn assembled properly in the wheel, but it doesn't work when I push on the ring or center. Does anyone have an exploded drawing of the horn ring assembly? My E mail is [email protected]
There is a decent drawing in the assembly manual which you can get from any Chevelle parts place. Do you hear the relay click when you push the horn? In the steering wheel, you the horn should blow if you jumper the little button which goes through the wheel to ground. Another problem could be if the space between the wheel and the turn-signal housing is not adjusted properly (loosen bolts which strap column to dash for adjustment). Good luck. --- Carl
1 - 2 of 2 Posts
