Ok so I've been lagging on starting this build thread.
I'll start off with the suspension parts prep. and painted pictures then a few pictures of the suspension installed in the next post.
I'm using Global West stage 3 parts all around and modded the LCA's for the Del-A-Lum bushings. They all had to be repainted using single stage TCP/Global metallic Cobra blue, the body is TCP two stage paint using the same color with 5 coats of clear and it still needs to be color sanded.
When I started the final body work last July I realized there was rust hiding everywhere and every last inch of the car was some how dented so it was a long hot summer for me.
Absolute worst most rusted out and dented body on the face of the planet, roof rails gone, most of the rear fenders were rusted out as is typical on these cars. I had to replace the entire front end with fiberglass parts, it took me 6 months of hard work to get the rear half of the body back in shape. Not to mention the floor boards in the front were completely gone and had to be replaced with custom sheet metal work.
Luckily the frame and body mounts were still solid, I didn't need to perform a frame off because no salt or snow here in Cali. In fact some of the original undercoat that protected paint on the bottom of the car was still like new.
Apparently powder coating has a life span and around here it was going down hill after just ten years. This seems strange to me because the parts were in a garage installed on the car the entire time.
