I just got a65 AM radio to replace the Sparkomatic AM/FM radio that was in the car. It has 3 tabs in the back corner of the radio. I can't find anything on the rest of the internet as to what each tab is for and the connector on the car is no longer there. Do any of you know the purpose of each tab? I am assuming one is hot, one is ground, and one is speaker, but then maybe ground is the case and two are speakers? Any help is very much appreciated. Thank you!
-----edit---/---//-/
Disregard previous info...
Turn the radio around so the rear faces you. The 3 connections will be on your right and the antenna plug hole on the left
Now, as you are looking at the connectors left to right...
A B C
A=ground return for speaker
B= speaker +
C= 12 volt power input
Case of radio is ground connection for power.
Do not use a speaker rated at less than 8 ohms.
Discussion Starter #4
i just got a65 am radio to replace the sparkomatic am/fm radio that was in the car. It has 3 tabs in the back corner of the radio. I can't find anything on the rest of the internet as to what each tab is for and the connector on the car is no longer there. Do any of you know the purpose of each tab? I am assuming one is hot, one is ground, and one is speaker, but then maybe ground is the case and two are speakers? Any help is very much appreciated. Thank you!
thank you!!!!
