Wipers - on the 2-speed units it's a worm gear drive system, so you probably won't be able to turn the motor (through the output arm) because of this.
I rebuilt mine, but it's so long ago I've forgotten the details.
Turn Signals - Do your brake lights function correctly?? The turn signal switch makes/breaks the brake light circuit, and "inserts" the flasher circuit into whichever side (L or R) that the lever is thrown.
Tough to T-shoot with the info you've provided.
