The time has come to pick a motor and I need help from you experts. I've been out of the hot rod game for 20 years, and I'm at the point in my project to pick a motor. The drive train components already selected are 200R4 trans, 12 bolt with 3.73 posi, all the typical stuff, Hotchiks rear control arms, 2 inch drop spindles and disc brakes up front etc.. I'm not looking for an 11 second quarter mile, but I don't want a slow poke either. I've thought about everything from a ZZ4 small block to the 502 crates. My mind and check book are open , so please help me decide. Edlebrock makes a 410 hp crate based on the ZZ4. I'm confused by all the choices. I don't want something I have to tune every weekend. Help.
i could give you a million good motors but those are the motors i would like, you might not have the same interest in engines as i do. i would go with something that would pump out a few rpms, and a wicked lope at idle, your gears are perfect for some high winding. all i can say is do what makes you happy. if your concidering a zz4, you might as well get a 383. that way you can get a bit of low-end grunt, the more the merrier when it comes to chevells.
Well you asked for it so here go's.
The 64/65 have limited rear wheel well area
So big rubber Big bit is hard to come by.
for this reason I lean towards the SB motor.
A ZZ4 or the 385hp fastburn 350, are proven reliable engines. You still have great reliability easy to keep tuned a noticeable loopy idle and enough grunt to fry tires on you 64. If you want WOW in a SB try the new MOTOWN 410 cu in from world products, I think it comes in at 470HP A real Killer SB in a BOX.
My .02
Wayne
personaly i like the FI. no maintanance engines. how bout the ramjet350 or if you checkbook is really fat, the ramjet 502
1970 SS396 AKA 454/4spd
My Chev-Hell Page
GOLD Member #783
Ft.Worth, Tx
(OO=ss=OO)
I'd go with the World 415 or 427 small blocks... All new castings and make serious torque and HP all in one package.
'65 Maliblue 406SBC/PG TC #811
'97 HD Softtail Springer
Sold my '94 1LE Camaro...
If I was going to build my 64 convert. I'd build a 327 with the duntov 30/30 mech cam/4 speed/4.10 with 255/60R15. I don't think you can get much bigger meat under the back.
Joe Yoder
BADBU68
LSE Motivated
one word BIG BLOCK...nothing makes you more proud to show them your engine compartment
Bob West
1972 Malibu 454+.030
TH350-3.73's
1.79 60 ft.
12.06 @ 112.89
