I'm installing a painless kit in a 64 chevelle, and having some trouble with the wipers.
I made jumpers and installed them to the terminals and found that putting the yellow/black to the + and the blue/black to the - the wipers worked. I also noticed the old switch had one terminal.
Along with the painless harness i'm installing late-model switches, and the wiper switch has 3 terminals (for different speeds) and a main input.
Going with the knowledge of the battery test, i grounded the blue/black, and put the yellow/black through the switch. and the painless main + for the wipers to the main input on the new switch.
I need to know a couple things. Will i be able to wire this with my new switch? And did i do the circuits backwards? Should i have put a main positive right to the motor, and then used the switch to break ground? Am i correct with the idea that the yellow is + and the blue is -??
Most of the equipment i'm connecting to is aftermarket with diagrams supplied with it, and the heater/brake and headlight systems are something i've tackled in the past so it was no problem.
Wiring is quickly becoming one of the things i enjoy alot, despite my current delema.
thanks for any and all help!
