1 - 13 of 13 Posts
The right brake light on my 64 Chevelle is not working or worked intermittently, the turn signal works fine.
I have checked all of the wiring and with the turn signal working it would seem that all wiring is ok.
It has a tilt column with the turn signal switch mounted on the lower part of the column.
I can not find any information on this switch and it’s operation in any of my manuals or online.
Question is could my problem be a bad switch? And is the switch adjustable etc.
An help, information, or ides are much appreciated.
yes you adjust the cable to the switch , and you must move the column up and down to ensure its adjusting correctly. its a
PIA set up
I did mine by trial and error. It’s a little sweet spot your find
why a new column? the 64-66 may be unique but it is a valuable option to have
Here is a switch of you think you need a new one, good luck!
The 63 corvette uses the same style switch on there one year only column. I am betting the 63 shop manual has some info on them
59 thru 62 full size Chevys also used one that looks like that, though it's a different part number.
Reactions: LeoP
1 - 13 of 13 Posts
