Horn will not blow. I checked the horns before I installed them and they both work fine. All parts are new, turn signal switch, cancel cam, horn relay and both front engine harnesses. I have a meter, can someone give me a starting place? By the way, blinkers and brake lights work fine. One other note, the alternator is not hooked up. Just trying to give as much info as possible!
Thanks,
Ron
Thanks,
Ron
