Hey guys, just wanted to pick your brains about my Canton 6 qt pan. With the stock oil pan on the 350 in my '69, I had clearance between the pan and the crossmember. With the Canton pan on my 406, I had to shim the engine up to get the pan off the crossmember. This is with the same solid motor mounts and nothing else changed. I don't like the shims being there and was wondering if anyone knew of a motor mount that would raise the engine about an inch and if this would cause driveline angle problems. Thanks.
