21 - 35 of 35 Posts
1971 Chevelle. Carb’d 6.0 LS Th350 3.90 12 Bolt. 1972 Greenbrier Wagon 489, 700r4 3,73 12 bolt
Nice, looks like you changed your cam?
I just changed gears, hoping that picks mine up finally.
Discussion Starter · #25 ·
id like to do a 150 to 200 shot dry and tune with the terminator x , but that tuning is over my head at the moment, still battling hot engine light throttle , or barely blipping throttle and engine dies, sometimes starts back up without throttle usually needs some throttle, 2 foot driving at the track,,,
Hot engine light throttle might be too much timing. Mine was hot egt’s at idle, had 28*. Dyno guy dropped it back to 26* and cleared that up. Highest mph was at 28*. But I am running a carb and not FI. Not up on efi.
Mine loves nitrous. From 7.70’s /12.00’[email protected] na to 6.80’s/ 10.70 @125 on 125 shot. Still more in the tune, havent had a chance to run it this year.
Might need more fuel at idle. with the 850 idle mix screws too lean, it will go almost 16.0 afr coming up to a stop. If the primary jet is too lean it will misfire.
i did go to custom pat g cam, and an 8in a-1 5500 convertor,
Running good!
Pat G seems to have a good rep. I'm running a BTR but would consider a Pat G cam after all the positive reviews I've read.
Discussion Starter · #32 ·
new best today. 5800 da. 7.005, 97.8mph,,,,
i can almost. taste a 6.99 time slip
Reactions: Geo71
Is 5800da considered good or bad? I went out Friday nite and da was 2800. Very humid.
Wish mine ran good on motor like yours, nice numbers.
What heads did you end up with cathedral or square (LS3) guessing cathedral being the TBSS intake.
Pat G knows how to spec a LS cam for sure. Ramp rates and those reduced travel lifters do really make a difference. Would only use solid or reduced travel lifters on any LS build.
Discussion Starter · #35 ·
cathedral 243. today 15mph headwind , 5000 da 1.53 60ft and 4.48 330ft, 7.02, best 330 ever,,,,
Reactions: FrankU
21 - 35 of 35 Posts
