Does anyone make a reasonably priced sheet metal intake for a 572? Dont want to spend thousands. See many for LS/LT
Thanks,
Bill
Thanks,
Bill
Run Forest Run...those are terrible.Tall deck or short deck? Single or dual quad?
Holley Sniper 835011 Sniper Sheet Metal Fabricated Intake Manifold Big Block Chevy
Holley Sniper Fabricated Manifolds continue to push the aftermarket by introducing intakes for Big Block Chevy Engines. These Intakes are good looking, perform well, and offer an extremely good value for a performance sheet metal style intake manifold. Each manifold is precision fixtured and...www.holley.com
If you want power from one going to cost you $3000. If you want looks only the Holley will work.Does anyone make a reasonably priced sheet metal intake for a 572? Dont want to spend thousands. See many for LS/LT
Thanks,
Bill
Yeah I wasn’t into the spacer look so I bought a Dart Cast for raised deck and had it ported.Yes, trying to go EFI, and really like the looks of the LS sheet metal intakes, which now are reasonably priced. I had one made by precision metal 11 years ago for an LS7. And no, it made virtually no difference on a chassis dyno vs the stock intake, but sure looked nice. Cost 2200 then, now I see them for about 600. Hogan's are around 5000. Don't mind using adapters at this point if I could just find one.
Thanks,
Bill
I been doing alot of research and unless you want FiTech or Edlebrock Pro flo XT EFIDoes anyone make a reasonably priced sheet metal intake for a 572? Dont want to spend thousands. See many for LS/LT
Thanks,
Bill
Yes you can, a holley ecu doesn't care what manifold it's using. Just like wiring is wiring and injectors are injectors. Just be prepared to have to do some custom work.I been doing alot of research and unless you want FiTech or Edlebrock Pro flo XT EFI
Your going to be spending $3,500+ for a custom billet manifold.
I don’t like either ECU so I am trying to see if I can use Edlebrocks manifold and fuel rails with Holley HP ECU, injectors and throttle body.
Sent from my iPhone using Tapatalk
