1 - 20 of 35 Posts
So I'm finally able to play this game!
Built this motor 3 yrs ago and then had a freezing problem and broke the block! Never really got it to run right, so I took it to a pro to assemble it this time and then dyno it. Dynoed it Saturday and found out what was wrong, the carb I bought used but "in great shape" had been "converted" to run on e85 by an "expert" and was pig rich! No wonder I couldn't get it to run!
So anyway. 555 BBC with 325 AFR heads, Dart intake and a 900 cfm "dyno" carb, custom Staub solid roller (722/705 lift, 253/263 @ .050, 107 lobe step.), 10.3:1 compression, everything else your basic build. Nothing fancy in the oiling system or anywhere else. Ran 2 1/4" headers on the dyno for the O2 sensors. I have 2" for my Camaro.
Guesses on the HP? Chris came through again and it made more than I had asked for!
Post the dyno sheet tomorrow and see what everyone thinks.
Well north of 700
Question:
Was the cam specified for this engine combo (with the AFR heads)?
I ask because I've read so many discussions on this board where the AFR heads don't need much if any split favoring the exhaust side. Your cam "Staub solid roller (722/705 lift, 253/263 @ .050, 107 lobe step.)" has a 10 degree split; seams more like a split that the discussions point to being needed with ported stock or other aftermarket heads.
Not trying to be controversial, just looking to expand my limited knowledge.
I`d say about 815 HP with that carb. A Holley 1150 HP would add a few more.
We have a similar motor but we use a single pattern cam UDHarold Hyd roller with wider lobes and less lift.
Discussion Starter · #16 ·
Ok so here are the dyno sheets I promised. Made 12 pulls and this is last of them. All were on 91 octane pump gas and I am very pleased with the results! Could always make more power, but this makes so much power downstairs that it should be fun trying to make it hook! And I won't have to spin it hard so it should last a long time! (I hope)
Let me know what you guys think, as many of you are way more experienced in this than myself. (actually my first dyno run ever!)
BTW I had asked Chris for 750 steetable HP, I guess he came through again! :cool:
Congratulations:thumbsup:
Discussion Starter · #18 ·
Well north of 700
Question:
Yes the cam was spec'ed for the AFR heads. Guess that's a question for Chris.
nice results. tire shreader for sure
1 - 20 of 35 Posts
