Can someone explain the purpose of the windage tray that fastens to the main bolts on a 96 5.7 vortec ? Not that I built the engine and forgot to put it on...ooops.
Its meant to keep, in the simplest of sense, the oil from rotating with the crank. Allowing more oil to stay in the oil pan. Its not directly needed in some cars, but with high RPM engines, its a must to prevent the oil from running dry in the pan.
this might help, the main function of the windage tray or screen is to help maintain a higher volume of oil covering the oil pump pick-up, and reduce the oil in the crank case dragged around the lower engine with the spinning crank assembly
look at the link
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
