Right now I've got a 65 with a powerglide and console. Im going to put a 4spd in soon. When I buy one of the reverse light swiches, does that just plug into the main dash harness and I can throw out the auto console harness?
You don't need the console harness. You will need a backup lamp extension harness, available at M&H. It attaches to the connector left when you remove the console harness. The other end has a molded, about 1 inch diameter, rubbery grommet/connector. You will punch a hole in the firewall the G/C is held in place in the hole. The correct backup switch has wiring with a rubbery connector that mates to the G/C. I believe the location for the hole and the exact size can be found in an assembly manual.
