Anyone know where to find these seals that attach to front edge of rear windows in a 1966 4door HT? Mine are shot. Are they same length as the 1/4 window version on 2door HT cars ?
Also, what is the little rubber coated guide clip that the window rests against along the roof rail called ? One is old and rubber ( vinyl?) Has cracked off. Thought about plasti-dipping to renew them, but not sure that holds up in heat / weather.
Thanks!
Greg.
Sent from my HD1907 using Tapatalk
Well, Metro Moulded Parts say they don't have an exact part, but that this one: Rear Side Roll-Up Window Seal, for Hardtops and Convertibles-VS 3 likely will work. Maybe not as good as the steel insert type, but way better than these hard-as-rock-and-breaking rubber seals on the car.
Ordered, we'll see how it works out.
