Looking putting a car together as a driver. I want a 496 with the 4 1/4 stroke and engine guy wants 522 with 4 inch stroke. Car is a 1966 chevelle 2 door hardtop. Just a driver but want it to be a bit of a spirited car that can dip into the 11s if there comes a need. What would you guys do.
RH
You and I have similar tastes 😂
Build the most reliable, most tame, easiest to drive package which still runs the number you’re looking to run. I also built mine to run on the tires I intended to run.
With valve springs, we’re talking cams under 0.600” lift and an engine which can drink the fuel you intend to purchase. I built my engine to satisfy all these boxes. I’d have to believe with a set of AFR 265s, my car would be in the 11.6-11.7s with 2.56 gears and stock stall, on 225/70-15, that’s with a 496. Why go for extra expense if you don’t need it?
On the other hand, if you had a big bore block, would you really only want to run 11s? My goal would be 10s with 2.56 gears 😂 I’d build a 565 with AFR290s and a fairly mild cam, and it would lay down serious grunt.
