Just changed the valve springs on my 781's from 924-16 comps to Straub Industries springs... unfortunately, it didn't change a thing... it does not run good at all, and it is fouling the #2 plug. This thing should be all over the road and eat tires like no one's business, but it doesn't... it falls flat on it's face before 4000 rpm. I have the anti pump hyd roller lifters I believe they are Morel. I have them set at 1/2 turn past lash for preload. It starts fine, but fouls the plug #2 immediately. maybe not foul, but it is VERY black, and the rest of them are nice milky brown. It is a 850 HP Holley. I have it jetted at 78/84's with 3.5 power valves (new) I did add a new ignition system and it does have a rev limiter, but I have the rev limiter set at 6800 or so... It is a Mallory Comp 9000 and Hyfire IV. It has to be something simple. I'm to my wits end... My mechanic friend thinks it may be in cam timing... Wouldn't it not start well if it was in the cam timing? I ran it straight up and it is a Big Mutha Thumpr, which is not the most desirable camshaft, but I would think it would run better than 4000 rpm...especially now that I have good valve springs... Thanks Chris!:beers:
Good Guys is less than 2 weeks away, so I don't want to do anything drastic as it runs and drives, just falls on its face...
