James, I don't know for sure, but it is probably based on a truck engine and probably has peanut port heads. If it is a truck engine, that probably only means that it has 7.5 or 8.0 to one compression. Hope this helps.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
progress has little to do with speed, but lots to do with direction.
By truck do you mean tall deck? It's not a tall deck. The easiest way to tell is to look at the front of the motor it will have a 1/8in oil tap right in front of the intake manifold. If it a std height block like it should be the only thing wrong are the heads and they are no problem to change.
[This message has been edited by Mike Feudo (edited 12-12-2001).]
The only thing you need to watch out for is a Tall deck block. Those were installed in medium and heavy duty trucks and are only 366 or 427 CI, I'm talking C-60 or bigger type trucks. The motor home should have a short deck motor. You need to get the block casting # found on the pass side shelf behind the heads, if you can pull a valve cover off, then you can ID the head casting#, 75 should be large oval ports as the peanuts did not come on till 76 model year. Probably a good score, but get those#'s and post em here someone will decode them for ya
Frank W
G-3 Chevelles Rule
74 Laguna Type S-3 Warmed over 305
4 bolt 454 now in garage 3.42 Posi
90 Mustang LX Notch 5.0/5 speed daily driver
Homepagehttp://www.chevellepages.com/folingo
Club Page clubs.hemmings.com/bearingburners
Thanks guys! I should have said I didn't want a tall block. I'll do whatever it takes to build up a standard block. I'm going to check it out Saturday if things fall in place. The deal is an eng/trans for $650 but its still in the motor home. Mileage is said to be 140,000 and was running when parked. May be some potential there.
Elcaminos are special!
I'd rather walk around with a Chevrolet hubcap in my hand than drive a Ford
work in progress
Big James Elky(AKA Ol Paint)
www.chevelles.com/showroom/workgoeson1.jpg
www.chevelles.com/showroom/newpaint1.JPG
