Here's my Procharged combo for comparisons:
.030 over 454, stock 2-bolt block with ARP studs
stock cast crank, stock 3/8 rods
TRW L2465 Pistons ~ 9.6:1 compression
Comp NX284 nitrous cam
Non-ported 241 oval ports with 2.19/1.88 valves
800 cfm Holley modified by Sd Concepts
Old Procharger P600b without an intercooler
I ran on pump gas and never had a problem on the street, I would run 104 race gas or add in some 110 when racing. If I would have had an intercooler I would have stuck with pump gas. I ran this combo for 4 year and ran 10.67 letting off and 128.5 mph on anther pass in a 3800lb '69. My Aeromotive fuel pump quit while going down the track in July and I burnt holes in all the pistons. I beefed up the bottom end of the block and I'm going to add a 4.25 stroke 4340 crank, rods, and flat top pistons. I'll run my existing heads and cam and add an F1R or F2 with intercooler and hopefully make an easy 800 rwhp.
