Hi all! I decided to start another thread where I will share the process of refreshing my 454 big-block. But it is more important for me that you help me avoid critical mistakes when assembling the engine, since this is my first work with a big-block. It's not a big dollar build, but just an engine refresh because I had to take it apart and wash all the oil passages.
So, I completely disassembled the engine, because camshaft and lifter were damaged, which I talked about in this thread
454 big block camshaft problem.
All parts of the engine, except for the above, are in good condition, in my opinion. I have checked them and made the necessary measurements. So I only ordered a timing kit, camshaft, hydraulic flat lifters, bearings, piston rings, gaskets and the book How to rebuild the big-block Chevrolet.
I lightly honed the cylinders with a hone tool, then washed out the block and other parts.
Before
After
The crankshaft was polished in the machine shop. I checked the clearance with the plastigauge - 0.0015" on the 1-4 main journals, 0.002" on the rear and 0.002" on all rods journals.
When I installed the rear main seal, I found an o-ring. I installed it under the rear main cup, did I do it right?
When I wanted to install the pistons, I realized that the new rings do not fit the pistons, so I had to order another set.
Mistake in the piston ring set?
576.1 KB
712.6 KB
3.4 MB
841 KB
5.8 MB
2.8 MB
3.3 MB
