No ideaWhat lifter rise is the advertised cam duration rated?
I had DELTA cams resurface a set of Crane solids I had experienced human error on. Seems to work quite well.My cam grinder( Spirro) refaces older lifters, and has older cam cores, to what extent I don't know.
Thanks. Theres only one way I run timing on a automatic trans, and most of you know thats all in, and thats because it makes the most power that way. 41 degrees, it was snowing and humid on my last test. But I'am not done testing yet, I have another 2 carbs to test and a oil change to make.How much initial timing and how much all in? Sorry if I missed that info earlier.
I love me some 427 bbc! Real nice power on a mild cam.
Joe
same. Mine made the best power at 43 degrees. I just checked, you have a bit more squeeze than me and I’ve got more cam and “better” (expensive) heads. Damn, feels like I should be doing better.Thanks. Theres only one way I run timing on a automatic trans, and most of you know thats all in, and thats because it makes the most power that way. 41 degrees, it was snowing and humid on my last test.
What heads are you running?same. Mine made the best power at 43 degrees. I just checked, you have a bit more squeeze than me and I’ve got more cam and “better” (expensive) heads. Damn, feels like I should be doing better.
you’re making great power.
Joe
it that due to the elevation you are running these engines at?? [mile high+ elevation]Thanks. Theres only one way I run timing on a automatic trans, and most of you know thats all in, and thats because it makes the most power that way. 41 degrees, it was snowing and humid on my last test. But I'am not done testing yet, I have another 2 carbs to test and a oil change to make.
I'am @ 6400 feet, not sure I understand the question, I will say the 820 head is not as good as a 781 or 049, I almost scrapped these heads during my build, but already had the pistons. And actually it might keep me from getting 500 HP, and more important what if it runs 11.03 best............was it worth it?it that due to the elevation you are running these engines at?? [mile high+ elevation]
does the head material and chamber play into the equation?
AFR 265’s.What heads are you running?
If it makes you smile, of course it's worth it.I'am @ 6400 feet, not sure I understand the question, I will say the 820 head is not as good as a 781 or 049, I almost scrapped these heads during my build, but already had the pistons. And actually it might keep me from getting 500 HP, and more important what if it runs 11.03 best............was it worth it?
Ok I think I understand your question, chamber and water in the air play into it.it that due to the elevation you are running these engines at?? [mile high+ elevation]
Tested @ 28 inches 4.350 boreWould be nice to see the head flow numbrers.
How much power/torque you would loose without notching the bores of the block? I guess your heads flow better In your block than In your flowbench.Tested @ 28 inches 4.350 bore
.300 224
.400. 272
.460. 291
Long port
