I just picked up a 400 small block, and plan on building a 427. Does anyone know of any good combos so I can get the max HP out of it, for a good, reliable street car? This is what I'm looking in to so far...
-Edelbrock Performer Air-Gap Intake Manifold
-AFR Street Cylinder Heads
195cc Intake Ports
Straight Plug Type
65cc Combustion Chambers
64cc Exhaust Ports
1.290'' OD Hydraulic Dual Valve Spring
135 lbs. Seat Pressure
.600'' Max Lift
-Lunati Street Avenger Cam
Adv. Duration: 265°/265°
Gross Lift: .454''/.454''
RPM Range: 1000-5000
-Speed Demon 750 Double Pumper Carb
-TCI Breakaway Torque Converters
2200-2400 rpm
-Crane Cams Energizer Roller Rocker Arms
Ratio: 1.5
I'm trying to get between 500-600 HP. Do you think it's possible to get that with the parts listed?
195cc Intake Ports
Straight Plug Type
64cc Exhaust Ports
.600'' Max Lift
2200-2400 rpm
Ratio: 1.5
