Well I got a set of pistons and rods from a swap meet. They are forged std. bore 11:1 compression 427 pistons. I was told they were 454 pistons. So I have a good std. bore 454 block and a 454 crank that needs turned. So should I build a 427 or a 454? ill have to get 454 pistons or a 396 crank. The 427 pistons are a 35cc dome and I have 3 sets of heads, 215 oval ports 101cc, 781 oval port 119cc, and 840 rectangle port 107cc.
The current setup is 460 with the rectangle ports. But I would change that combo for the best to build another. I have 2 cars im trying to get going. One to be nasty the other to be streetable.
I have a Oval Performer RPM intake and a Summit 1302 Cam setting on the shelf at the moment.
So whats the ideas?
So whats the ideas?
