I'm helping out a friend with his 69 SS.
Engine has rocker noise and engine runs poorly
Engine lost a set of ported stock heads a couple years ago , different owner then,so very little info not sure what the failure was.
When I started helping , rockers ticking like they were loose and comp roller tips had burnt ball and sockets some worse than others. Oil just runs over rockers .Replaced rockers with Harland Sharp rollers and adjusted valves. Also changed oil
Engine ran good for about 200 miles, then same rocker ticking came back worse when engine is hot. We have checked spring pressure , coil bind , rocker arm geometry and checked oil pressure with a mechanical gauge (56 psi hot) taken at the lower left of engine .
Wondering if maybe cam bearing failure or cam bearing spun could cause this issue or maybe just bad lifters.
Engine is a used 427 short block that from what I can gather had a lot of 1/4 mile passes on it , cam is a Crane hydraulic flat tappet PowerMax .534/.553 lift, Heads are new Merlin II's, Harland Sharp roller rockers.
Any idea's or help would be great, this one has me stumped .
Thanks Bob
Thanks Bob
