Rebuilding 78 400. Looking for opinions on the following list of materials in the event that I am missing something or if there are things I don't need. I don't mind replacing things that might not necessarily need it while I have it apart. I already have a transgo 1-2 kit. Motor will be 450-550 horse 461 so nothing too crazy.
A34652A Sprag, (Z) 400 / 4L80E intermediate, (34 element CAM TYPE)
U34555 400 Early direct drum 65-70, Smooth cam type !!
34006AF Master kit, 400 1965-UP (FULL RING KIT),FIBER
B34024E Band 400 / 425 / 475 / 3L80E / 4L80E Rear
N34022 Band 400 / 425 / 4L80E Front 1964-98
34030 Bushing kit , (X) 400
34200 Thrust washer kit, 400
A34684 Gear, 400 governor gear, 1965-UP
A34654 Roller clutch, FMX / AOD / E/ 400 / 4L80E LOW
44160R Modulator: (Z) 350 / 400 Single RED stripe adjustable
34444A Case connector, 400 1 Prong, 1968-UP
34420 Solenoid, 400 Detent 1964-up
34201A Bearing kit, 400, 3 bearings & 6 races
D34476 Silencer Ring, 400, .177 inch thick,
M465SC Trans Prep GREEN Transmission Assembly Lube
A34010B Filter, 400 flat brass 1967-UP
