Thank you. So what if I did use a head gasket that had seam holes? would it also be fine, just 'dumb'?They will work fine. Use the 350 gasket. No need for the steam holes in a 350 block.
Thanks. Apologies for being vague, here is more color. i have some old heads off my motor that I want my dad to have for his 350. That is where the 350 engine/400 heads question comes into play.The 400 gasket will work but it has a larger bore size and is not really correct for the 350 block. Not sure if any of the other holes are different.
Ok, did not realize what block you had. No need for the steam holes with the Motown block because it is a saimese bore and you will be fine with the 400 gaskets with the steam holes. The holes will not hurt a thing.Thanks. Apologies for being vague, here is more color. i have some old heads off my motor that I want my dad to have for his 350. That is where the 350 engine/400 heads question comes into play.
When pulling my heads I see that my 400 block (world motown block) doesn't have steam holes, but my new heads are drilled for steam holes. Further, I had bought gaskets for steam holes and just installed them. Before I get much further I wanted to ask those more intelligent than me on the situation how bad an idea this may be on the dumb scale.
Hi Bill,Ok, did not realize what block you had. No need for the steam holes with the Motown block because it is a saimese bore and you will be fine with the 400 gaskets with the steam holes. The holes will not hurt a thing.
Your Dad can put the old heads with the steam holes on the 350 block, Also no problem and no need to worry about the steam holes. Just use the 350 gasket.
You are fine with both![]()
Thanks for the feedback, Tom.As Bill mentioned, you will be fine with either a 350 or 400 gasket.
Personally, if I had 350 gaskets, that would be my first choice. BUT, if I had 400 gaskets, I would not hesitate to use them. MOST 400 heads gaskets, such as Felpro, are a superior gasket because they have to positively seal a smaller surface area.
You are right,BUT, all SB400 heads had the large chambers (76-80 cc). When using factory Chev heads on big cube small blocks (383-400+), I have had good results with the early style 327-350 heads which have about 64cc chambers and 2.02/1.6 valves and flat top pistons on 91 octane NON-ethanol gas.The 400 heads to stay away form are the 487-X heads as the X means they are 80cc's so the 350 will have super low compression.
These are some OG afr 195s but still have 75cc chambers so compression will be relatively low.The 400 heads to stay away form are the 487-X heads as the X means they are 80cc's so the 350 will have super low compression.
I have not seen 350 head gaskets with steam holes , just sbc 400 head gasketsThank you. So what if I did use a head gasket that had seam holes? would it also be fine, just 'dumb'?
Agreed, only 400 gaskets have steam holes.I have not seen 350 head gaskets with steam holes , just sbc 400 head gaskets
I ran my junk 400 with those 80cc heads with a puppy cam and ran 12.80's with it. Two weeks later with a stock set of Vortec heads all else the same, the car ran 12.26 quite a pickup with heads only. Funny thing was those old 400 heads had 1.6 exhaust valve stock from the factory. I had like 6 circle track guys waiting in line to buy them, 1st guy gave me $225 for those junk heads, I was happy with that.You are right,BUT, all SB400 heads had the large chambers (76-80 cc). When using factory Chev heads on big cube small blocks (383-400+), I have had good results with the early style 327-350 heads which have about 64cc chambers and 2.02/1.6 valves and flat top pistons on 91 octane NON-ethanol gas.
Also, I have never done it, but the next SB400 that I build with 400 heads (76-80cc), I plan to use domed style pistons. I'm thinking this will result in the range of 10.5:1 compression.
