Wife and I picked it up. Heavy but not to bad.
Bolts to body mounts. 2" X 2" X .125 wall tubing. Dimensions before car was tilted. Under body 6' Leg going up the side 4' Front post to body mount 5" rear post to body mount 7" A couple gussets and pads for the feet. You could also add casters so you can roll the car around. If you need to roll the car the other way just unbolt the arms and remount them on the other side.
