The clutch, the tires and the suspension dictate how hard you can leave. My Z car with the 302, on the wood and just step off. Car had 9 inch slicks, slapper bars and good shocks front and back. Car would pick up the wheels about 10 inches.to any of the boy's that own , or have owned , 4 - speed standard cars . when coming out of the hole , do you rev up - off & on until you feel [ hear ] the app rpm , then let er out . or do you rev to a certain rpm , once looking at the tack , then let it out , or ; other ? & what would the term - sidestep it ? mean that i have heard . any info back appreciated
5.86...HOLY HOLE SHOT BATMAN!!They also don't run a steep enough gear, the Z had 5.86 out back, a big difference.
What was the 1st gear ratio, 2.2?the Z had 5.86 out back,
Most of the time it had the 2.2 first gear, but I also used a wide box.What was the 1st gear ratio, 2.2?
The '70 had a McLeod in it for a while. It ended up taking a major dump at the drag strip. I've heard it was good clutch for hard hook ups.Most of the time it had the 2.2 first gear, but I also used a wide box.
As for 1/4 mile speed, 110 was average. The car was in high gear by the 1/8 mile. The only way the 302 works is to zing it so the gear is necessary.
I used a clutch called a cleaning lady, a unsprung disk that was full metallic and a long style three finger pressure head. All the parts were McLeod, brutal. That clutch works but slipping it is not a option. Try loading the dog on your trailer.
Ram made these units and I think you are right about the name. McLeod made them as well and I was using a McLeod pressure head so I used their version of the "cleaning lady".Hey Wally, Was that clutch made by RAM ( the cleaning lady). =)
Jeff
