Actually a pretty good mix here.I know this forum is heavily slanted towards the BB, but c'mon guys. He said stock. Stock '72 LS5 454 big blocks only made 270hp and it got worse after that.
270hp NET.....for 3 letters,NET is a very big word.I know this forum is heavily slanted towards the BB, but c'mon guys. He said stock. Stock '72 LS5 454 big blocks only made 270hp and it got worse after that. When people hear 454 they automatically think of the '70 LS6, but I'm doubting thats what the guy has.
I'm just saying, do not rule out the 454.270hp NET.....for 3 letters,NET is a very big word.
& like Kettbo (George) stated,all it takes is a little savvy tuning & a very little well chosen parts and a stock sounding 454 can make 400+hp.
It is well known here that the '72 LS5 is identical to the '71 LS5 which was rated @ 365hp. the '72s were DE-tuned to pass emissions.
I say the 454 whoops up on the 383.
I agree!:yes: but even IF the 383 hooks better,it will have to out-pull the 454 in midrange.......I'm just saying, do not rule out the 454.
He who hooks first will win :yes::beers:
Actually the small block is exactly 145 lbs. lighter when both had cast iron heads. I've weighed both in a '67 Camaro and the difference was 2740 lbs.(sb) vs. 2895 lbs. (bb). The car was a gutted race car. The small block has way better gearing than the BB Camaro so it should accelerate much better and be a couple hundred, or more, pounds lighter. It also must have a good set of heads to make over 500 h.p.Even if the h.p. is within 20-30, remember the big block is 200-240 lbs. heavier. Excess weight will add to understeer problems
and the 454s massive torque negates the 145lb. weight difference.Actually the small block is exactly 145 lbs. lighter when both had cast iron heads. I've weighed both in a '67 Camaro and the difference was 2740 lbs.(sb) vs. 2895 lbs. (bb). The car was a gutted race car.
The low compression 454s aren't nearly as strong as the 10.5-1 compression, LS-5 engines of 1970. Most all of the rats that fly have lots of compression. My friend had a 375-396 that ran low tens, it was rated at 11-1 but had close to 12-1 real compression ratio. His '71 El Camino had a 454 and wasn't very fast, high 13s with slicks, if memory serves me correctly. P.S..... That stock cam in the oval port 454s was originally designed for the 396 and really is too small for a 454.and the 454s massive torque negates the 145lb. weight difference.
One guy with a 383 that he says is putting out 520hp....& another guy with a 454.....that he says is stockout of curiosity....what are the build details?
350hpi would like to know what this 520hp 383 has in it?
