I am finally getting ready to finish off a rebuild on the 327 for my 64 300 sedan and was wondering what top end you guys would recommend.
Here are the specs so far on the build:
'64 327 Small Journal Block, with 4 bolt splayed caps. Stock 327 crank std/std. An old, but still new, set of Eagle H-Beam Rods. Forged Dome Pistons. I would anticipate 11.4:1 with a 64cc head. The machine work is already completed and the short block is together.
I always used a close ratio Muncie and will likely use the M22 I have this time around. Although I do also have a fully built TH-350 sitting in the garage that may find its way in there at some point. Torque Converter would be selected after the rest of the combination is done and if I go that route.
I am using a 4.56 gear.
Street Manners are not a major concern. This vehicle is a toy that only sees short trips. It has no options so idle quality is also not much of a concern.
I was looking at the new AFR heads either 180 or 195cc. Should I be looking elsewhere or would one of those fit the bill? I am also on the fence somewhat about whether to select the street or comp heads. Any thoughts?
I will select a cam after I finalize my head and intake selection. Although, in the past I always just called G.K. and this time around that is no longer an option. So, if someone wants to recommend a particular cam or cam manufacturer I am all ears.
Finally, on the intake. Would I be correct that I should just pick up a new RPM intake and port match it to the heads rather than attempt to use any of the following which I already have: Edel TM-1, stock "Z/28" intake, or Holley 300-36?
Thanks for the help.
