Currently running the following set-up until I get my BBC done:
1968 camaro
327 ci
461 heads
eddy perf. rpm manifold
holley 750 vac sec
headers
2.5 exhaust through flowmasters
th-350
3.73 posi
2800 stall
I had some problems with rocker arm "ticking" and when I inspected the lifters I noticed some cracks and chips in the bases, therefore I removed them all. They are hydraulic lifters. I then decided to remove the cam and indeed some of the lobes were worn and some had little cracks in them as well. I identified the cam as a comp magnum cam with .244/.244 dur and .501/.501 lift. This car ran very well, but I can't help but wonder if this cam was too big. I was looking through the voodoo lines ans saw one that may be better. It was the voodoo 276 hydraulic. In the description it best matched my existing set-up with the stall and the gears, headres, intake etc.. Would I be even happier with the next one down which is the 268? I must say I loved the sound of the magnum cam but I also heard these voodoos sound pretty mean too. Appreciate any and all help. I know its a camaro but I've been on here before and you guys are by far the best!
1968 camaro
327 ci
461 heads
holley 750 vac sec
headers
th-350
3.73 posi
2800 stall
