I need help picking a camshaft for my 327.
Total Weight 2300 lbs
Transmission: Tremec TKO
Rear ratio: Undecided
Tires: Undecided
1966 327 +.030
Decked to .002 (estimated 9.5:1)
Align honed with ARP studs
Scat 4340 rods
Hyperutectic Sealed Power H660CP (-5 cc valve relief)
Pro-topline Vortec castings 64cc
Weiand 8121 intake
Looking for a recommendation for a solid or hydrualic cam for this engine.
Going in a street rod, lightweight.
Want a cam that makes power to 6000 plus (if possible)
I thought about the 350/330 Horse cam and adding 1.6 rockers. Not sure where this one will fall off in the power band.
G
Mike,
I bought one for a similar application recently. 327 going into a 2500 lb 260Z.
I went with a custom ground solid flat tappet. [email protected] 112 LSA from Delta Camshaft in Tacoma.
It is basically the Comp 282S on a wider LSA.
They use Comp masters.
Good place to deal with.
If you need one in a hurry, I'm not using this one and am from Denton.
jakeshoe said:
Mike,
Check your PM
