I am using Mr Gasket 5800 composition type head gaskets, and both the heads and decks have been surfaced. Please tell me what the stainless steel rings that are adjacent to the bore edges are called, and also, what is their significance. Are they rolled (clamped) in place, or are they solid. The reason I ask, is that I used a Dremel grinder to remove about 003" of the stainless rings adjacent to the valve reliefs in order to exactly match the contour of my (cast iron) head's combustion chambers. I notice that the stainless rings seem to be double layered (crimped or rolled around the edge), and I'd like to know whether or not it is acceptable for me to have done so (grind the ring). Or did I compromise the gasket.
Thanks in advance.
Joe
Thanks in advance.
Joe
