305 Head question
1009 4
I have the early 434 casting heads on my 305, when I had them rebuilt I measured the valves at 1.5" Exhaust and about 1.92" Intake. At that time I had read somewere in the library that both the 305 and 350 for those years (77) both had the 1.94/1.5 combo. I recently got a nice book Chevrolet Small Block V-8 ID Guide by Pierre Lafontane, which has tons of info, VIN tag and stamping Suffix etc, saved me from buying a 73 Impala with a 400 emissions sticker, but a 145 hp 350.
Anyways, supposedly all 305 heads had 1.72" intakes except for 80 up 4 barrel engines 1.84" Was I retarded when I measured the valves, I measured the widest point of the face on a metal drafting ruler with 1/64" marks, The intakes were nearly 2" wide as I recall (10 years ago) 1.72's should have been obviously smaller??? or did someone stuff in 350 intakes previously?? This has been puzzling me for sometime now.
Frank
Read your post and couldn't remember, so I troted out and checked my "wood pile" of 305 stuff and there on top was a set with 1.94 dia. valves. The problem with 1.94s in the small chamber of the 305 was excessive shrouding so I doubt that 1.94s are much better than the 1.84s.
Harley
Maybe somebody put 350 heads on it because the 305's were cracked or something.
Malibu 307 (aka 406 smblk)
69 SS 396(aka 454)
Wolf in sheeps skin
Head casting no# 354434= 75-79 262/267/305.
Ref. Mortec.
Harley
Harley, you were correct about the full casting #, the date codes were J156 and J276 Both correct to be the original heads for the motor. When I tore the motor down, It appeared all original, no cyl wear still had crosshatch and no ridge, Had a good cam, the factory ones were soft, that had been changed. I wonder why the LG3 was not listed with 1.94 intakes??
Frank
