Trying to get the fire started
LOL!!!You got a lot done in 4 minutes.
Epoxy primer, or something to seal it... I thought that most primer wasn't good for sealing moisture, and it could start to rust under the primer?LOL!!!
BTW
Get some primer on that thing before it rust!!
EpoxyEpoxy primer, or something to seal it... I thought that most primer wasn't good for sealing moisture, and it could start to rust under the primer?
Start a project thread on yours also. I know I'm always up to follow an L78 build. What was it new...4-spd or T400? Do you have a lot of parts? Do you have the original engine, trans and/or rear axle? Photos?It is never to late to start. I have began on a 69 L78 SS i took apart 30 years ago myself. Finally found a young man that is awesome with a welder and he put on a full metal roof. The old vinyl top had ate some much metal replacement was the only choice. Now that that is fixed , lets go . Motivation is where you find it......feed on it and get it going.....great progress.....
I too am "restoring" an L78 that hasn't been driven in over 33 years (I last drove the car in 1985, engine blew, and "life" happened)... Somewhere on here I started a "build thread", but while the spark is still there, its pretty weak... Gathered a lot of parts, did a little work, but still a ways to go...It is never to late to start. I have began on a 69 L78 SS i took apart 30 years ago myself. Finally found a young man that is awesome with a welder and he put on a full metal roof. The old vinyl top had ate some much metal replacement was the only choice. Now that that is fixed , lets go . Motivation is where you find it......feed on it and get it going.....great progress.....
