1 - 2 of 2 Posts
Got an 3 wire alt. from 86 monte carlo.
I've read that you can turn a 3-wire alt in to a 1-wire is this true?
So the #1 goes to the gen light and the #2 goes to the batt terminal on the alt.?
Is this what I think is what helps the alt excite?
Do you have to use a jumper wire to make 3-wire work?
The one wire is a self exciter, so is the #2 terminal the exciter for the alternator?
So all i need to do is jump the #2 terminal to the BATT on the back of the alt., then wire from the back of the alt. to the battery? Is this correct?
Sorry for so many questions, I just want to make sure I get this right as I am still learning, and at the bottom of my cash pit and wits?
So what, am I any closer to getting it? :confused:
the car does not have the factory wires, and i am using after market gauges.
1 - 2 of 2 Posts
