Will a 29.5 x 10.5 r15 slick fit on a 70 chevelle. Without tubbing. Rollin a fender a lil is fine.
On my 68, I have 10x29 goodyears that fit easily with NO trimming or rolling of fender lips.
The wheels I use are Centerline Autodrag 15 x 8.5" with 4 7/8" backspacing.
You can fit a larger tire on a 70 than on a 68 or 69, so you shouldn't have any trouble as long as you use the right wheels.
On my '70, a Hoosier radial slick, size 30x10.5x15 fit on a 15x10" Weld wheel with a 5.5" BS.
I did have to slightly grind some of the upper portion of the wheel lip and molding.
