1 - 20 of 27 Posts
i currently have 256 gears in my rear end if i switch to 373 gears will it make a big diffrence when i do a burn out i know it will make my car run on a higher rpm on the highway but im not really worried about that
If your goal is better "burn-outs" get some bald tires and install a line-lock. Your car won't be fighting the rear brakes and this will be easier to install then new gears.
1970 SS454 LS6 11 second street car
do you guys hold the brake down when you burn out ? and is it ok to to that
For a second or two to get the tires going.Won't hurt anything
But,with a 2700-2800+ stall you won't have to :D
Just punch it :thumbsup:
I just switched from 3.55s to 4.11s. Though this isn't what your switch is, I can tell you the difference is HUGE. I've also run 4.56s before. My dad's Camaro had a TH350 and 3.73s and it drove real nice. I think you'll see (and feel) a huge difference. Even a 3.55 would be good. Kind of a compromise. I really like the 3.55s in my Chevelle for the street.
Dude, I went from 4.10s to 2.73s, kind of the opposite of what you're doing to the extreme. I could not use 1st gear at all with the 4.10s and it would get sideways going into 3rd if you stayed in it. I have huge meaty 275/60s on the rear too, it would liquify them with anything more than 1/2 throttle. Also, say goodby to gas mileage, although you have already stated that you don't care about that. I went from 7-9 mpg to 13-14 and I only put 2000-2500 miles on the car a year. But yeah, making that gear change will make it seem like it has 100 more horsepower.
BTW, 'brake-standing' always reminds me of a classmate of mine with a [email protected] 229 v-6 Monte Carlo who would pound the heck out of his car to get it to squeak one rear tire for about three feet. IMHO, if you can't break 'em loose with just torque from a standstill, you need more torque.
Discussion Starter · #16 ·
i breaks them loose but it all depends on the pavement. it smokes the crap out the tires but only on the pavements in parking lots. you know when the paint on that black tar like crap. on the street it doesnt sit n spin not like i want it too. it does a nice smokie burn out when i turn and stand on it. im running a 350ci with 330hp / 400 ft.lb its no punk by far. with the 256 gears it just isnt doing it justice. but from what you guys said a gear & stall swap should change all that
Keep us posted how the swap from 3..5's to 4.10's work out ET wise. I have been considering going from my current 3.50's to 3.89's. Thanks!
1 - 20 of 27 Posts
