I can't figure this out. Left turn signal blinks quickly. Right turn signal blinks normally. I have the headlight and taillight assemblies out and sockets removed from housings so I can easily see the bulbs. All bulbs seem to be working fine.
I'm using the right side lights as a reference because it blinks normally/apparently as it should.
When I turn on the right turn signal with key on run/engine off, this is what happens...
Front
White cornering lamp on
Amber upper element on steady/lower element blinks
Rear
parking lamp "194" is on
White taillight upper element steady/lower element blinks
When I turn on left turn signal with key on run/engine off, this is what happens...
Front
Rear
parking lamp "194" blinks dim
White taillight upper element blinks dim/lower element off
Can you help me fix my wife's car? Thanks. :beers:
Front
Rear
Front
Rear
