All,
Im planning on putting a 496 in my 69 chevelle. It has a 2 bolt 289 block 454 in it now. Plans are to bore and stroke. My question is if i should hold out for a 4 bolt or just continue with the 2 bolt. I have ordered AFR 305 cnc heads as well as a custom cam from cstraub. Engine will be anywhere from 650-730hp and 600-690 lbs tourqe. Could put a 4 bolt cap conversion on the 2 bolt but is it worth it? Need some good advice. The 289 cast block should be a high nickle block if im not mistaken. Built in 74. Most likely a truck engine. Also came with 781's
