Hi,
I am currently finishing up a complete re-wire of my 70 El Camino. I have a 1994 Camaro Z28 alternator that I got for free and would like to install it. It is 140 amps and it will bolt in directly like my old externally regulated alternator did. Does anyone know where I can get the connector to attach to the 4 smaller posts on this particular alternator? Also, does anyone know what each post does? It seems to be slightly different from the pictures in the Tech Reference section of this site, but I could be wrong. Thanks!
Ryan
Arizona State University Student
Mechanical Engineering
1970 El Camino
Upgrading on a student budget - Jealous of those with cash!!!
[This message has been edited by Elusive_R (edited 02-05-2002).]
For the connector try Brown and Brown or Chapman parts dept. they may have it.
The 4 connections on the CS144 should be marked P L I and S. P is a tach connection. L is the connection you will use(brown wire from the regulator) if you are using the GEN indicating light. I is the connection you will use if you’re not using the indicating light. L in some cars is used for a volt meter connection. Note: if you use the I connection (no GEN light) you will need in line resistance I don’t know the value needed. I recommend you use the GEN light.
L or I and the alternator output connected to the bat or horn relay are the only connections needed.
[This message has been edited by Elree Colby (edited 02-06-2002).]
Thanks Elree!
One more question though - since my terminals aren't labeled 1,2, etc.., from which terminal would I need to jump across as shown in the tech reference section? Is this even necessary with this alternator?
Thanks again,
Ryan
1970 El Camino
