Anyone know what wire is the ground for the dash lights? My lights are dim and the controller has no effect on them but the dome comes on so I'm thinking bad ground.
Under the left side of the dash just above the E-brake there is a 10 mm bolt that is probably loose. This bolt is straight up and attaches the dash carrier to the body, and is also the ground. I'll bet if you grab the dash at the bottom it will move.
Pretty sure the dome comes on when grounded. Probably need a new controller.
Dan
