OK here goes another interesting wiring question. When I tested my wipers on the car they worked for a second and stop in the middle of the windshield (keep in mind I did a frame up resto which means I had to pull this mechanism off). Anyhow I for a second thought it was the wiring but it was not.. Anyhow I gone ahead and took a ride over to Ground Up Restoration for a new wiper motor (hidden). So I easily installed the wiper motor onto the car and when I went to test it the motor still did not work.. The wires are on correctly and I did try every possible way to see if it would work, but I did no help... Is their something I am doing wrong? Where is the ground to the wiper motor?? When I hit the wiper motor switch is only makes a clicking noise? Does the washer motor have anything to do with the wiper motor and the wiper movement? All Help is Appreciated?
ACES Member #2987
1972 Chevelle SS
1987 GTA
1998 Camaro SS (Y2Y)
1978 Pontiac TransAm
ACES Member #2987
1972 Chevelle SS
1987 GTA
