1 - 2 of 2 Posts
Should the printed circut board for the gauges have a black ground wire direct to it? or is it grounded thru the mounting of the dash?
I've got it all back together and the gauges don't work. the temp gauge pegged pass 250 the gas gauge doesn't work and the amp and tach are dead.
There should be a black ground wire attached to the metal back of the cluster. The printed circuit card has three or four locations where a screw grounds a copper trace to the metal back.
1 - 2 of 2 Posts
