1 - 2 of 2 Posts
The gauges in my 72 ss are not working and I noticed one of the "clips" that hold the fuses in the fuse box had completely broken out of the box. It looks like I need to replace the entire box. Is this something I can do or should I bring the car to a pro? Where can I buy a fuse box? Appreciate any help.
You would have to replace the entire underdash harness. Expensive and very time consuming. I have several trashed out fuse panels. Tell me exactly which wire (color, fuse name) and I will send you the clip with the wire attached. Solder the wire to the one on your fuse panel that is broken, wrap and insert the clip.
1 - 2 of 2 Posts
