I HAVE A NON AIR 1972 CHEVELLE MALIBU..HAS A SINGLE SPEAKER IN CENTER OF DASH....I WOULD LIKE TO REPLACE IT... NEED TO KNOW HOW TO REMOVE AND INSTALL SPEAKER :confused: ......THANKS.....
1, There are 6 screws holding the dash pad to the dash. 2 of the screws are hiding behind the glove box door. Open the glove box door to access them. Remove all 6 screws.
2, Set the emergency brake. Move the transmission lever to the lowest gear. This will get the lever out of the way to remove the dash pad.
3, Pull the dash pad towards you. There are clips on it next to the windshield and pulling it towards you releases the clips.
4, After you remove the pad the center speaker will be right in front of you.
