bought a new used dash from e-bay i had a very good wireing harness i put in the dash is there anyway to test the dash an harness on the bench before i install it?where do i hook up the pos n neg on the fuse box?all help will be great
thanks phil
You can connect the + at the fuseblock, connect it to the terminal labeled BAT. The ground can be connected to the metal back of the cluster. I would use an inline fuse, 5 A or less, at the battery connection when testing. A short using an unfused source can easily burn a trace on the circuit card.
You may already know this. The harness needs to be a 72. I see the harnesses on e-bay listed as 70 71 & 72.
