There are about 5 different DOMED hoods out there.
The plain domed hood was a standard part on all 70-72 SS Chevelles.
The option for CI hoods was
ZL2-----------------D88 is the
STRIPE code.
Early CI hood.
Late CI hood. The left picture at the top is the later hood I do not know when the change occurred, but the difference is in the cutouts of the under side bracing. Later hoods have the larger cutouts. Again, I don't know when the change occurred from early to late style.
The 4th domed hood (NON CI hood) is the aftermarket version from Goodmark
The 5th domed hood is a CI hood from Goodmark.
The Goodmark hoods are basically good hoods, they look and fit good, and are the later style with the larger cutouts---------------------BUT, they are not as heavy as an original GM hood.
Our 70 Malibu Conv has a Goodmark CI hood and I love it! Fits and works perfect.
I used a different check valve to my vacuum hose for the outer door so that it does not slam shut so quickly.
