1 - 2 of 2 Posts
I have purchaced a SS gauges dash (w/tach) and the wiring harness as well. Do I need to have the wiring harness for the engine compartment for a gauges dash car as well?
I cant see to find the wire to hook up the tach.
Sure do. Just went thru this a few weeks ago. The correct engine wire harness for a gauge dash has the tach wire as well as the correct wire for the temp sensor. By the way, you will need a different temp sensor for the gauge than the idiot light sensor. Actually, it turned out to be a really good thing to replace my engine wire harness. Found broken wires as well as ones that soon would be, especially the ones to the starter which are subject to alot of heat. I recommend M&H wire harness not only for the quality but for the correctness. Good luck!
1 - 2 of 2 Posts
