1 - 11 of 11 Posts
1970 chevelle ss
would anyone know the measurements or pictures of mounting a right side mirror not remote, that you actually can see something out of Ty
Discussion Starter · #2 ·
i reposted this question sorry
hello would anyone have pictures or measurements of a right side mirror installed on a 70 chevelle SS that i can actually use, thanks for your time sorry for the mix up
:cool: Perhaps the easiest thing to do is to remove your left mirror completely. Then take a sheet of paper and tape it to the left door. Then pencil in all the holes and door edges on the left door. Redraw the holes/edges in black ink. Flip the sheet over, line up the edges on your right door, and use a center punch to get the holes located. Drill your holes too small at first, and sneak up on the size hole you need for a tight fit.
If you happen to have the inner door off you could JB Weld a piece of metal inside against the door skin as a reinforcement...
Ty
I can get you pictures and measurements of mine this evening. Keep in mind the pass side mirror was a dealer installed option and as Bruce said, there is no "support" structure built into the door for it. It does work though. I bought the mirror set from Ground Up and they fit well and from the drivers seat you can actually see out of the mirror without it hitting the door glass.
Reactions: roadster601
bart sure wow that is great, please send better than nothing Ty.....
Re: 1970 chevelle ss
Go to the web site www.morrisclassic.com for side view mirrors. I had originally purchased mirrors from OPGI, What a mistake. The passenger mirror flew off doing 50 mph and hit the rain gutter stainless trim at the rear passenger side. Morris Classic has well made side view mirrors that you can adjust and lock them to the desired position with two set screws. The passenger side is concave which provides better viewing and you can get them in tint or non tint. They are expensive but well worth the money. And they are exact factory reproduction.
Jay,
Thank You for the Compliment & Purchase.
Our mirrors are Patented.They Eliminate the Blind Spot
plus stay adjusted. You can tighten the 2 recessed screws in
the mirror head to adjust the spring tension on the ball& socket.
3 yr warranty. Members get 5% discount.
Reviews & Pictures on pro-touring.com
Thx, Billy
Jay,
Thx, Billy
hello Billy would you offer a military discount
1 - 11 of 11 Posts
